My car is a 2005 911 base model 997.
I had a tune installed and am having some issues with it. I only had the tune done because I put high flow cats on the car and had a stumble. The tune company is wanting a data log with the following actual values.
1. Engine RPM
> 2. Injection Time/Injection PW
> 3. Ignition Angle
> 4. Pedal Position
> 5. Actual Throttle Plate Angle
> 6.Actual Lambda Value Bank 1
> 7. Mean Fuel Trim Bank 1
> 8. Actual Lambda Value Bank 2
> 9. Mean Fuel Trim Bank 2
I started out trying to get this done with Durametric. The first obstacle I ran into was Durametric did not have compatibility with the variant on my ECU. I called their support and they were able to quickly get this resolved. The problem that I have now is that I don't have any actual values for the Actual Lamda Value for Bank 1 or Bank 2. Durametric basically told me that they have nothing to do with the values and if its not in there they can't help me.
The following is all the Actual Values in Durametric that I have to choose from.
1.      AC pressure
2.      Actual Camshaft angle bank 1
3.      Actual Camshaft angle bank 2
4.      Actual throttle plate angle
5.      Air Mass 1 (sensor)
6.      Altitude correction Factor
7.      Ambient Pressure from DME
8.      Ambient temperature
9.      Camshaft deviation bank 1
10.   Camshaft deviation bank 2
11.   Catalyst Monitoring time bank 1
12.   Catalyst monitoring time bank 2
13.   DME supply voltage
14.   Distance towards power failure
15.   Distance with check engine on
16.   Driving cycle counter
17.   Engine compartment temperature
18.   Engine compartment temperature (sensor)
19.   Engine load
20.   Engine load (SAE 1979)
21.   Engine oil temperature
22.   Engine oil temperature (sensor)
23.   Engine roughness cylinder 1
24.   Engine roughness cylinder 2
25.   Engine roughness cylinder 3
26.   Engine roughness cylinder 4
27.   Engine roughness cylinder 5
28.   Engine roughness cylinder 6
29.   Engine speed
30.   Engine Start temperature
31.   Engine temperature
32.   Engine temperature (sensor)
33.   Exhaust temperature stream
34.   Fuel Level
35.   Fuel Level adaption at close idle (RKAT)
36.   Fuel Level adaption at close bank 2
37.   Fuel trim adaption lower load (FRAU)
38.   Fuel trim adaption lower load (FRAU)
39.   Fuel trim adaption lower load (FRAO)
40.   Fuel trim adaption lower load (FRAO)
41.   Fuel trim mean value
42.   Fuel trim mean value
43.   Idle speed specified RPM
44.   Ignition angle
45.   Ignition counter misfire direction
46.   Ignition map RON department
47.   Ignition Safety retardation
48.   Injection time
49.   Intake air temperature (sensor)
50.   Intake- air temperature
51.   Lambada controller delay time
52.   Lambada controller delay time
53.   Loss adaption
54.   Mass airflow (MAF)
55.   Mass airflow (hot film MAF + tank vent)
56.   Misfire counter cylinder 1
57.   Misfire counter cylinder 2
58.   Misfire counter cylinder 3
59.   Misfire counter cylinder 4
60.   Misfire counter cylinder 5
61.   Misfire counter cylinder 6
62.   Misfire detection adaption 0
63.   Misfire detection adaption 1
64.   Misfire detection adaption 2
65.   Misfire Range
66.   Misfire Range
67.   Misfire Range
68.   Misfire Range
69.   Nominal Camshaft angle bank 1
70.   Nominal camshaft angle bank 2
71.   Nominal Throttle Plate angle
72.   O2 sensor downstream
73.   02 sensor downstream
74.   Operating time since power fail
75.   Oxygen sensor (LSF) Voltage ah.ofcatc.1
76.   Oxygen sensor (LSF) Voltage ah.ofcatc.2
77.   Pedal Encoder potentiometer 1
78.   Pedal Encoder potentiometer 2
79.   Pedal Value
80.   Radiator fan request Value
81.   Relative fuel quantity via tank ventilation
82.   Relative secondary air mass
83.   Retardation cylinder 1
84.   Retardation cylinder 2
85.   Retardation cylinder 3
86.   Retardation cylinder 4
87.   Retardation cylinder 5
88.   Retardation cylinder 6
89.   Tank ventilation valve
90.   Throttle potentiometer 1
91.   Throttle potentiometer 2
92.   Timer as end of starting
93.   Transmission oil temperature
94.   Vehicle speed
95.   Warm up counter
Charcoal canister load
I am looking for other means to get a quality data log. I have just purchased an ODBlink MF wi-fi unit. I also have a few phone apps like Torque Pro, OBDdoctor pro, and OBDLink. The problem I am having is they have several Lambda PID's to choose from and am not sure witch ones to use.
If anyone has suggestions it would be greatly appreciated.  even if the solution is using a totally different data logger.
