I have a 2006 Cayenne S.  Ever since I've had the vehicle - I get the 'check left/right cornering lights' message on start up.  It appears the lights are on all of the time.  Guessing it might be a relay - but can find no reference to the cornering light/s relay in the manual.  Does anyone know where the relay might be located - or have any other suggestions for what might be the source of this issue?  Thx!!!
I would suggest that first you pop out the headlamp unit and clean the connector on the back of the headlamp. These are prone to poor connections. Some WD 40 would help here.
Sent from my SM-G935F using Tapatalk
