Hello Friends. Sorry for my poor english. I am brazilian and need some help. I have a Cayenne 4.5S 2006 and the engine started to fail. I suspected fuel pump failure and upon verifying I could see that the right pump was working inconsistently. Her pressure rises and begins to fall slowly until almost the engine stop and it rises again. I checked at the pump itself that the electric pulse is defective, that it ends up in the pump and then it is stopped. Any suggestion?
How does the car run on the left pump only? Remove fuse from right pump and cycle ignition off and back on. If the car runs good on left pump but bad on right pump, you can almost guarantee the right pump, inside tank piping issue, or power to the right pump is the issue.
You could also swap the fuses and relays to rule out that as a problem.
Edited by lewisweller
  • Like 1
