I have a 2003 TT X50. What are the pros and cons with going with an unsprung GT2 clutch disc? I know that my tt uses the same pressure plate, flywheel, and throw out bearing as the GT2.
thank you!
Excessive gear rattle, and harsh engagment would be 2 of my reasons.
If you stay with a dual mass flywheel the trans noise at idle will be more noticeable but not as loud  as a lightweight single mass unit with an unsprung disk.
