I have the 4 zone AC option.  The fan for the back seat only works intermittently.  Sometimes it works, sometimes it doesn't.  And sometimes it goes to max speed for a few seconds all by it self.  To me, it seems like the regulator/resistor would be the most likely culprit, however for the life of me, I can't locate it on the parts diagram.  Is it in the fan blower itself?  I was going to replace the fan unit parts #95857202203, but before I do, any other suggestions regarding diagnosing this problem?  I have a icarsoft por II, but did not notice any codes.
Edited by Ghost Ryder
Does the icarsoft allow you to activate (turn on) components? If so - try turning the fan on at various speeds and see what happens, then report back. The most frequent failure appears to be the blower itself - and it looks like a royal PITA to get to, some fairly heavy duty interior disassembly required.
I'm able to control the fan with the rear or front controls.  Its just that sometimes the fan do not turn on, or it shuts off by itself despite what's displayed on the control.  And sometimes the fan would go on full blast for a second all by itself.  Really strange.  If I leave the control on, and the fan does not work, a few minutes later, it may start working again all by itself.
