Well, you came to RennTech and posted, but you gave us no clue what is wrong, therefore you are not going to get much help.  What is or is not happening?  What sort of troubleshooting have you done?  Did you check the fuses, switch, hydraulic cylinder levels, microswitches?  Is anything else not working correctly?  Do you get my drift?  Does it need to be reset by the Porsche dealer? Is there a CEL or any codes?  Probably your best bet is to get it to a Porsche dealer and have them run a diagnostic.  They have specialized software that will tell you what is exactly wrong.
Did you use the manual operation at any time, if so the cable drive for the clam shell has been disconnected. Check back if that is the case.
