Hello. I have a 1998 Boxster 2.5 manual. I just recently took apart the Guage cluster to replace a bulb. When I put it back together the fuel Guage started acting erratically, so I took it apart again to see what the problem was. It looked like the wires got kinked inside the cluster. None of the needles work now, but the digital speedometer and clock work. I bought a used cluster thinking that the kinked wires were the issue, but now the temperature Guage doesn't move and the fuel Guage doesn't work properly. Everything worked fine before I took it apart. Any advice?
