I have the factory sports exhaust on my 2002 Boxster. When the RPM is coming down back to idle the exhaust makes a slight rattle noise. I was wondering if this is normal? Is it just the bypass valves closing?
Not likely the valves - more likely a loose clamp or broken weld.
I have had the same problem - on mine, the entire valve assembly is loose on the driver's side. I can move it freely - It should not move at all.
It needs to be spot welded. Until I get a chance to do that, I took some stainless safety wire (ACE/Home Depot) and ran a loop around the valve and the nearest clamp and twisted it down tight.
I've had this wire in place for so long that I only remembered the problem when I saw your post- so at least a year.
The dealer suggested that I take it to a good muffler shop and they can spot weld it. It doesn't look too difficult.
Let me know if you can't figure this out and I'll post a couple of pics. Make sure the car is cool (or wear heavy work gloves) before manipulating the valve.
Edited by LemmyCaution
Could you post the pics it would help me out
Yes - give me a day or two - I need to lift the car in order to shoot the area.
Here's the photo - check the valves and make sure they are solidly mated to the bypass pipes.
There's one on either side of the muffler/system.
If the valve/valves are loose, you'll need to have it spotwelded in the outlined area.
