During an autocross yesterday, my ABS went out and the OBD says ABS FAILURE and the ABS idiot light is on. I have only basic ABS, no PSM
Brakes work fine, just no ABS.
I have a new found appreciation for ABS. Without it working, its really easy to lock up the brakes.
In searching, it could be a wheel sensor that went bad. I did find some info on testing them with a OHM meter, but there were several values mentioned and I don't know what the correct one is.
Anyone have any thoughts on troubleshooting the problem?
4 hours ago, JayG99 said:
2004 986 S
codes 4210 & P0501
I'm away from the shop at the moment, so working from memeory P0501 is for no speed signal, which can come from multiple sources:
Break or short in the wiring from the ABS module to the ECM
Break in the wiring from the left rear wheel speed sensor to the ABS module
Left rear wheel speed sensor is dead.
Pull the left rear wheel and check for a damaged sensor or heavy build up of brake dust.  If OK, check the speed sensor for resistance, should be 1.6-1.8K ohms.
Yup!
Swapped out one from my 996 and the ABS system works properly. Bad right rear sensor
it read .4k and the good one 1.8k
Cleared the codes and will see if the P0501 comes back
Edited by JayG99
3 hours ago, Loren said:
JFP is correct on P0501.
P4210 Rear right speed sensor
- open circuit short to ground/short to B+
For future readers of this thread, watch which year you are looking at as Porsche reversed codes on the later DME, making P0501 the right sensor on cars with a 7.8 DME, which the OP has:
