It's been a month since I've been getting this noise from front axle area. Can't pinpoint to what's causing the noise.
You can hear it especially while doing low speed cornering but at a high speed, the sound goes away.
I'm suspecting it may be a bad CV joint but that doesn't explain why it only happens at a low speed cornering.
Thought the KW suspension spring suddenly started to bind but looking at the video, it doesn't seem to be the case. Would like to hear from those who had a similar experience. Thanks in advance.
Had the same symptoms and sound on my outer CV on my old CTT. replaced CV, noise disappeared until the other side went about 4 months later.
