The rubber outter piece of the windshield has come lose, and flaps around if I go above about 55mph. The channel that it fits into, has somehow widened and no longer pinches the rubber part hard enough to hold it against the windshield.
Can these two pieces be removed and replaced, without removing the windshield?
 The windshield is perfect. I am just guessing there is no way to remove and replace the same windshield.
Take it to Safelite and ask them. When it comes to windshields and rear window glass, I think it's best to let those with the proper tools and experience do the work. It's also probably not very expensive. Good luck
