Just bought a CTEK with cigarette lighter adapter for my '03 996 Cab. After everything is hooked up I am getting a rapid blinking yellow/orange light above the "half full battery" and a solid green light above the "full battery" picture. Is this normal? Anyone out there who can help it is greatly appreciated.
Welcome to RennTech
Usually, a blinking light means that the 3 amp fuse in the line to the battery has blown.  Pull it and check it.
2 hours ago, JFP in PA said:
Welcome to RennTech
Thanks JFP. I took a look at the fuses and did not see one that was a 3 amp fuse. I also looked at the fuse assignment list and didn't see anything related to the battery. Any guidance?
How do you have the Ctek connected to the car?  The Ctek cable that connects directly to the battery has a fuse in the positive wire.  If you are using the lighter plug, there is a fuse inside that plug.
