The foam coming out the vents are the seals from the heater box diverter door seals which have dried out and are starting to fall apart.  To fully repair this, you need to disconnect and drop the heater box down (it is in the passenger's side under the dash), scrape off all the old seals and replace them.  Some people have simply removed them, but that allows some mixing of different air streams in the system.
Do a search on the topic, it has been written up on a couple of websites.
  • Like 1
