I am getting 0300 code and 0303 and 0306. i am thinking that my cat might be clogged or damaged inside. when i was checking exhaust the exhaust tip one side was warm the other was almost cold. i have notice that when i was warming it up in the morning that one side had condensation on the ground and the other didn't. any clues out there?
Edited by RoverRon
Chances are your CEL is flashing - If so, the car should not be driven.
P0300 Misfire Damaging to Catallytic Converter
P0303 Misfire, Cylinder 3, Damaging to Catalytic Converter
P0306 Misfire, Cylinder 6, Damaging to Catalytic Converter
Hmm... cylinder 3 and 6 are on different cylinder banks. Have the spark plugs been changed recently?
no i guess i will pull them and check them. car is in garage im not driving until this is fixed
