I heard a light rattle coming from the rear of the car. In the top's latch recess I found this: a light gray cap(?) about a total 1 1/2 inches long, having a hollow, very course thread shaft about 1/2 inch wide. The other end terminates as a flat disc about an inch in diameter, with a curved "basket handle." There are no markings such as a part number, etc. It shows no sign of wear, or having had any fluid on it.
My only conjecture at this point is that having the engine replaced recently, it might be something that temporarily sealed an orifice or hose on the new motor.
2001 2.7 Manual
I think they say a picture is worth a thousand words!!
You say the "top's latch recess" - that can't be where the top latches to the windscreen frame(?) I'm presuming you mean in the area where the top folds down into?
Here's my two guesses - if the threads are internal and it does look like a cap, it may be from the top of an oil bottle, these are sealed again so thats why theres no sign of fluid.
If the threads are on the outside, it may be part of the buffer that the clamshell rests on when closed.
Otherwise its a bit like "Guess the colour I'm thinking of?" "No, it was more of a lighter brown" :D :P
Please post a pic to put us out of our misery ;)
Edited by Laz
Thanks for the conjectures. I found in the back recess. Threads are on the outside. It's a very light gray, and it's not one of the flip-up fasteners on the carpeted engine panel. Sorry about no picture, but I'm still using a beautiful Canon F1 from way back.
