2001 996 C4 Coupe - The fan has just stopped working. No a/c, not defrost, no heat. I checked the D6 30 amp. fuse and it is ok. The fan runs on 12v supplied at the plug socket on the fan. I replaced the resister. What else can it be? The CCU seems to be woking. The lights light up and the fan speed indicator moves up and down with the +/- buttons. How can I test the CCU?
Thanks.
Lang G
Have you seen any foam bits come of the vents?
A common issue (as these cars age) is the insulation decaying and breaking up - it can even jam the fan.
Do you have Durametric to test the circuit and look for faults?
I have seen foam bits but I had the fan out and it turns freely. I do not have a Durametric (yet). Would the Dealer's system be able to detect a problem with the CCU? What can the Durametric detect?
Lang
