Hi Everyone,
I have a small wear spot on my '99 soft top that is about 1/8" in diameter.  The tough waterproof layer under the outer fabric is still intact, but I would like to stop the fabric from wearing anymore and creating a hole.  I use my hardtop 75% of the time, and I plan to replace the top with a glass one when the window finally breaks, so I am not looking to do an expensive repair on this top.  I was thinking of putting some superglue over the wear spot, Loctite makes a flexible/fabric superglue that dries clear.  Any thoughts on doing this?  Would a better option be to carefully hand stitch it back together?
-Rick
Edited by rick3000
formatting
Unless the problem is due to top misalignment, some wear spots are to be expected on any convertible top.
As JFP said...  plus there are numerous soft patch kit you can get to put on the inside to reduce wear at critical points.
But do realize at some point you may have to replace the top - after all the car is already 18 years old.
