I jumped the curb and the roll bars deployed.
1. Reloaded the roll bars per owners manual
2. Connected the code reader, roll bar selection did not load, said this option not their.
? is there a fuse in the roll bar control module
Are you using Durametric?
Try turning the ignition off for a few seconds then turn it back on - always do a full control unit scan first.
You may need to find someone with a PST2 or PIWIS tester. If it still not come up on a POrsche tester then the control module may be dead.
