I've got a '98 Boxster with the manual 5 speed transmission. It recently failed an emissions test due to CEL being on and fault code P1123.
Based on the advise in another post in this forum, I removed and cleaned the MAF sensor. I used my Durametric cable to clear the codes and took it for a 30 minute test drive. After that, I used the Durametric Short Test and am still getting P1123 as well as P1125 and P0150.
After more searching, I found posts that suggested a vacuum leak. I don't have a smoke tester, but with the car idling, I unscrewed the oil filler cap and the engine changed RPM's. I also tested by loosening a host that goes to the air-oil separator and the RPM's changed again. My understanding is that indicates a vacuum leak is less likely.
More searching and I found Mike Focke's post here:
https://sites.google.com/site/mikefocke2/oxygensensors
Using the Durametric software, I took the following measurements:
02 sensor voltages ahead of cat. c. bank 2
oscillates between approx 0.1 V and 0.8 V
02 sensor voltages ahead of cat. conv.
oscillates between approx 0.05 and 0.75
period seems a little shorter than the other sensor
Oxygen sensing cylinders 4-6
steady between about 1.0V and 1.06V
Oxygen sensing cylinders 1-3
steady between about 0.95V and 1.0V
Based on my understanding of Focke's post, the O2 sensors ahead of the cats are reading okay (although I don't know about the frequency of oscillation... could they be "tired"?. Also based on Focke's post, the last two Oxygen sensor measures look suspicious. They are supposed to be reading a voltage close to 0V, but are reading voltages close to 1V. In Focke's post, these sensors may oscillate if the cat is not working correctly. So, what does a steady high reading indicate? Maybe I'm not looking at the correct measures in the Durametric software?
Any idea what's wrong?
TIA,
Mike
You have codes of overly rich conditions on  both banks (1123 and 1125), and a code for the O2 sensor ahead of the main cat on the bank for cylinders 4-6 (P0150) either being short circuited or having lower than expected voltage.  I would start with the P0150 code and check the harness and the sensor itself for a short, and the short could be the sensor itself.
Couple of things to consider
1. Oxygen sensors are not expensive and easy to replace - do ll 4.
2. This makes subsequent diagnosis easier because it eliminates the O2 sensors - but not their wiring,
Check the plugs, tubes+sels and coil packs at the same time ?
