Is there a way in which the rear quarter windows could be permitted to be raised while the top is DOWN?
Two reasons.
1) it would greatly reduce drafts for my wife on cooler days.
2) it seems it would stabilize the door windows on the highway, which tend to move visibly as wind buffets them next to buffer trucks, etc.
I don't expect this to be a diy in any way. I just want to know if it's possible or if there's some type of interlock mechanism which prevents this in the top mechanism. From what peeking I have done, there doesn't appear to be any mechanical interference between the window and the top mechanism.
Any input is much appreciated.
Sent from my SPH-L720T using Tapatalk
Yes.  Push the microswitch on the latch when the top is down.  You need a pen or screwdriver.  Then you can raise the rear windows.
Thank you very much. :)
