Hello to all,
i am new to this forum. I have a 1999 Carrera 4 and a couple of days ago my drivers side quarter glass went down fine when I tried to raise it up it will go halfway and stop. Can someone guide me to any threads about this issue.
Sorry  have no photos (forgot) !. removed the side panel found the mounting bolts except the bottom one That one took hours to figure how to get at it.
Way at the bottom there ls a hole cannot remember If here was a rubber plug or not. you can put a socket in here to loosen the bolt/nut the regulator assy which has a slot in it.
2. lift the regulator out till you can remove the power plug via the speaker hole.
