Hi guys...i am having a moment because I am not sure where the power steering fluid goes in my 2010 panamera.
If someone can send me a screen shot or hints.
Also the fluid that I bought for the 970 is attached (CHF 202).
Any cons of using this fluid?
thank you !
CHF 202 is the factory fill and should be the only fluid used for power steering.
In normal operation the fluid should be checked but unless there is a leak it is highly unlikely you will need to top it up. The cap (green I think) near the left front fender has small dipstick built in.
