Hi all,
I am trying to figure out why my convertible top isn't working. The windows don't roll down a few inches when the latch is released, and the convertible top does nothing when the open/close switch is pressed. I have already tried 3 different microswitches and none of them changed anything. I did the relay test and failed on #8 which is pin #13 and #23, I get no voltage when The latch is opened. With The key turned on, I measured voltage at The pins where it plugs into the switch at 4.5v. Something is going on, can it be The relay? Or bad wiring from the relay panel? Any other troubleshooting advice or guidance would be amazing. The brake light comes on the dash so I don't think that's the problem.
avi
microswitch
