I have a Durametric reader.  How can I test to see if the post Cat O2 sensor on Bank 2,  is the problem or if it is a bad Cat?  I am getting signals from all 4 O2 sensors, but not sure how to tell if the Cat is doing its job or not.
Most likely the cat itself with that code because O2 sensors have their own codes.
After the engine is fully warmed up, at idle, the pre-cat sensors should swing between ~0.2 to ~0.8v every few seconds while the pos-cat should stay more or less at 0.7v flat. If the post-cat follows the precat voltage pattern, the cat is bad and needs to be replaced.
