This fuse operates the remote mirrors. convertible top and memory control unit.  Replaced fuse and with ignition switch in auxiliary position both the top and mirrors work fine.  Turn to start and the fuse blows.  Obvious cause or guess is the memory control unit.  So, what is it, where is it, can I get one and is it accessible to a shade tree mechanic?  Thanks for all and any suggestions.
Joe
The memory unit is under the drivers seat It has a fuse also, You can get it repaired at the CPU Doctors I don't have there web address right now but I used them and they replaced the unit
