Could somebody tell me where the Bose Amplifier is located
and which Panels need to be removed to get access to it?
I've a CT MY04, with PCM, Bose and CD Changer. Under the CD Changer
on the right (close to the emergency Kit and the Triangle) there is a metallic
box, but it is labelled something like "level controler" and doesn't look
like an Ampli.
Thanks a lot for your help,
Jean
Isn't it on the same bracket as the changer, directly above the changer?
That is correct - directly above the CD-changer. It's the box with cooling fins on top.
To get access you have to pull back the top of the side panel. It's a lot of trouble but can be done. Please let me know if you really want to get into such a project and I'll post instructions.
Edited by 356driver
Got it!
Thanks a lot to both of you Wingless and 356driver!
I didn't realized that there was something on top of the CDChanger...
I was looking more below...
Now indeed, I have to figure out out to get access to it, without removing this
"hard to remove" side panel...So instructions would be great!
Thanks again,
Jean
BTW My project is to see if I can insert a "Speaker Mux" into few of
the speakers wires, to connect them to a Cell Phone Car Kit (in addition to
do the "Mute all speakers", through the PCM). If the Bose Ampli access
is too hard, my alternative is to insert the Mux into few front Speaker wires
in the front doors.
