My 2005 Cayenne S makes a small wind noise on the rear left door. It seems as if the window does not go up completely. Is there any way to make it go up to the top?
Thanks in advance,
Are you referring to the whistling sound when the fan is turned up high? I get this sound when the windows and doors are all closed and the fan is on high. Check if this happens with the car stopped. The dealer couldn't figure out why this is happening and how to fix it. I'm going in again for my 20k service and I'll ask if they figured it out. It seems to be a common issue in the Cayennes on the lot.
If this is your problem, try opening the window a little or the sunroof. that seems to relieve the air pressure and stop the noise.
The sound happens even when the fan is shut. I believe the rear window does not go up completely. Is there a way to "teach" it (Similar to the 996 method)?
HEY GUYS:::
this happend to my 2005 cayenne i went to the dealer about it they fixed it !
they had it for 2 days
they had to reseal the doors but now all i hear is the roar of that german engineered v6
There should be a new TSB for the whistling sound at your dealer by now. It has to with little holes on the front door frames that need to be sealed up. Should be covered under warranty.
  • 2 months later...
Any idea what the bulletin number is??
