Thanks to Loren and his magic number cruncher I unlocked my radio and it came on - scans for channels - does everything but make any sounds - no noise - as if the speakers are not connected .
Is there a disconnect or something I turned off - does the front panel movement turn off the sound = anything >??>
Always helpful to add the exact model and year of your car - and radio in this case.
Also whether the car has an amp, cd-changer, or DSP (also factory or 3rd party for each).
2001 996 Turbo   CR 220  Radio, amp,  cd changer - all factory = checked fuses D8 9 and fuses on AMP - turn it on and hear noises but nothing from speakers =
I can not believe the number of posts on how terrible and unreliable all the sound systems in all models are - much more reliable sound at 10% of the cost if you want single CD player and radio @@@
I had that problem in my 2003 carrera cab. Turned out the amp was bad. Bought a used one on ebay and replaced it. All is good now.
Sent from my SM-G925V using Tapatalk
