My SAT radio and PCM 2.1 is stuck in some kind of "boot loop mode" and refuses to properly power-up. I do the 1/4/8 keypad reset and only the Porsche welcome screen comes on for about 28 seconds....then blacks-out. No sound heard whatsoever. Prior to this occurring the PCM was coming-on by itself randomly.
Two peculiar things I noticed:
a) No buttons on unit illuminate, day or night.
b) Dash center indicator shows NOTHING... not even "Radio Off, " or GPS dash Compass.
c) I am suspecting the instrument cluster and PCM are no longer communicating.
Edited by Zuffenhausen955
Might try disconnecting the MOST connection from the back and then try to boot it up to see if there is a difference? It would rule out that something else on the MOST bus is the cause.
