Does anyone have experience with replacing the cardan flange seal on the front differential? I have a leak on mine and was planning on replacing it.
But, then I saw a post on rennlist about a user that replaced the similar seal on his rear diff and the preload/rolling resistance was not set correctly resulting in the differential failing.
Can someone please shed some more light on the preload/rolling resistance part of the procedure? I am used to swapping out these seals from my past Audi but the procedure was straight forward, no preload.
Link for reference:
http://rennlist.com/forums/porsche-cayenne-forum/873910-04-ctt-tlc-thread-9.html
