Hard reset of the DME. I have a suggestion to reset the DME on my 2001 Boxster S. The procedure would be the same for a 996 and other years of Boxster ? So the issue may be of wide interest.
Question is how to do it correctly. Obviously there is  a potential to cause great damage.
What is the best resource to use to follow to do a Hard Reset of the Bosch Motronic 7.2 DME ,please.
This is the best I found but is 997
http://rennlist.com/how-tos/a/porsche-997-how-to-reset-ecu-387425
Edited by Schnell Gelb
No such thing as a "hard reset".
You can reset the drive mode for the throttle/idle as well as Tiptronic drive shift points.
For both of those just disconnect the battery for about 5 minutes.
Do a throttle adaption on egas cars and then drive as you normally would to "relearn" throttle, idle, and shift points.
It is normal for the car to run rough during the "relearn" process - but it should only take a few miles.
