I got a 2006 997.1 carrera, all the lights of driver door are not working, including those lights of window switches, and none of those seat memory are working as well. I've replaced the other door computer, and read out those codes from the old computer then write them to the new one. Replaced door lock, new seat memory switch still not working. And there's no any fault code. I also checked the fuses and nothing found. Have anyone ever encounter this kind of problem? (P.s I used PIWIS and test all the button are fine, and active when I press them, just somehow, no lights, no function at all, window switches can be use, but lights of window are not working.)
Edited by Stan622
