Hi Guys,
Aircraft engine Tech, currently replacing the clutch on my AutoX 1999 996 C2, first time tackling a clutch/IMS job.
While the clutch & Pressure plate are worn out, I inspected the flywheel, based on Porsche's TSB 911 8/02 1360, & found it to be a bit worn, but serviceable. Common knowledge suggest to replace the flywheel every second clutch change or every 100K miles.
Considering the high price of the flywheel, is it Worth it to replace it right now or I can expect it to last until the next clutch change?
Hars to say as you auto cross the car. For a DD the flywheel should last a long time.
A new clutch from LUK is about $400 shipped to your door from Partsgeek..if that makes a difference.
If your flywheel has more play than spec your may want to pull the trigger now.  Prices have come down on these quite a bit.   Rockauto has a DMFW for 400.
I'd probably do it while I had access to everything, but that's just me.  Just curious what your clutch looked like after 80k.  I'm sitting at 61k and thinking at 90 I'll take everything out and replace (RMS, IMS, clutch, plate, flywheel, etc).  I have an early '99 (bought new) and have never had a problem with leaks or the dreaded IMS (nor the clutch for that matter), and I drive it daily and change the oil at 5-7k. And I don't baby it.
Expand
I changed the clutch on my '04 at 70K miles because I was doing the IMS/RMS thing and it was only about 1/3 worn so would have been good for many more miles.  All depends on how it is driven though.
I am baffled by the arithmetic on your car.  Only 3K miles per year but daily driven?  That's 9 miles per day!
Expand
It wasn't a daily driver for most of its life, and it sat around a bit as I had a second car.  Only since moving to FL recently am I driving it more.  My 'commute' to work is only 15 miles through back country roads (no traffic and no start and stop), so even as a DD it is not seeing a huge amount of miles.
  • 5 weeks later...
I did clutch at 75tkm because cracked pressure plate. I checked flywheel and was ok. So keep an old one. No problem till now - 94tkm.
