When is it permissible to use the jack points that are under these covers?  I can't find any info on it.  The jack points are also recessed up close to the frames so I wouldn't even know how to use them?
http://www.sunsetporscheparts.com/porsche/cayenne/95550427200/2010-year/gts-trim/4-8l-v8-gas-engine/body-cat/splash-shields-scat
  • 5 weeks later...
The jack points under the covers on your side valances are for the jack supplied with the car.  They are not for using a floor jack on, if that is what you are thinking.  I've used them for brake pad replacements or anything else requiring wheel removal.
