The valve is a Schrader type, much like the one in a tire stem.  They are not made from the same materials however, so you need one for AC use.  To remove it, you need to recover all the gas out of the system using an appropriate system; then the valve can be removed and replaced.  From there it is a simple evacuate and test for leaks and a recharge with the correct amount of gas.
