Hi all, I just installed the cruise control retrofit on my C4S : cruise control set to "with cruise control" in DME (with Durametric Pro).
- I connected pin 1 cruise control to grey connector instrument cluster pin 17
- I connected pin 2 cruise control to fuse B7
- I connected pin 3 cruise control to grey connector instrument cluster pin 4
- I connected pin 4 cruise control to grey connector instrument cluster pin 1
However, when I read actual values, it says "cruise control readiness = off", whether I press the cruise control button or not.
No green light whatsoever.
Can anyone help ?
It should indeed. It looks like it does, but still I can't send a cruise control command to light up the green light.
I send an email to Porsche dealer if I can hop in for a quick PIWIS activation, no answer yet ...
I'll keep you up to date.
I don't really understand what you mean by "I can't send a cruise control command to light up the green light".
Can you read the instrument cluster input signals for the cruise control stalk?  How about the input signals for the brake and clutch switches in the DME?
