Hi.
Could someone please give me detailed instructions on how to change my current door speaker covers?
I have the grey sparkly ones in my MY99 996 C2 and I want to swap them over to silver ones I just bought.
I have read Loren's TSB on removing the door panels but it also says this is not necessary to get access to the speakers. Also the UK cars have an alarm system that just keeps going off if the battery is disconnected. I dont fancy mesing around with the airbag.
Is it an easy job to change these? If not Ill have to return them.
Thanks in advance
Ravi
You donot have to access the speakers, but still have to remove the door panels. Remove 4 hooks of the old speaker covers with some small tools (ie. flat bed driver). Not sure about the alarm though.
Could I have a bit more info about the door panel? I thought that there were specific screws that could be removed to allow the panel to swivel enough to reach the speaker covers. Many have mentioned on various threads here that the panels dont have to be completely removed?
Im really confused now-help!!
http://www.ecoutez.net/boxster/door-panel-removal/
Here is the link for instructions of door removal (Boxster). I recommend to remove the door before replacing speaker covers, because it's much easier and safer that way. When you can swivel the panel, you almost remove the panels anyway.
Sorry if I misled anyone. I was trying to show that panels have to be removed ro access speaker covers.
I installed Carrera door panels on Boxster, the speaker covers are installed same way.
  • 3 months later...
Hi
Did you ever get your speaker grills changed.
I need to change mine on my 2000 996 that also have side air bags.
Does anybody have any instructions to do this before I beaks something.
Thanks :beer:
Edited by 355Aloha
