Hi can someone point me in the direction of a wiring diagram for the last revision of 986 2003-2004 cars I.e dme 7.8 cars. If someone has the equivalent 996 wiring diagram I probably use that as well
thanks
Ross
Do you know if that wiring diagram is in it it says selected wiring schematics on the listing on amazon and it is a bit expensive in the U.K. At £100 for it not to be.
Check with Bentley, but you can also find lightly used copies for a lot less.
The Bentley manual cover says it covers 1997-2004 model years.
thanks
Ross
Boxster did not get DME 7.8 until model year 2005.
Do you want 7.2 - or are you trying to put a later engine in the car (with DME 7.8)?
I have the 3rd dme for the 986 cars
and my climate panel ends in 10
the dme is 996.618.604.00 it is a different engine than what's supposed to be in the car but it is the last of the 986 3.2 engines.
My car wasn't originally 7.8 I have moved and adjusted all the wiring following tholyoaks posts with the exception of the air con I have got the appropriate climate panel now but it needs some of the pin outs moving around. I also expect to find a couple of other things won't work quite right and the wiring diagram would really help
Ross
