So after troubleshooting everything the shop said the front struts on air suspension need to be replaced. We sent them to Rebuild Mastertech. Rebuild said that both of the bushings had severe leaks.
The suspension was rebuilt and now been installed. The shop is now saying the think the compressor is bad. The cannot get it to go up. I am getting the following codes
000328 Compressor Tempature Limit Exceeded
000286 Service Mode not Complete
C12097 Check Air Conditioner Regulator Control Unit. (I know this is not related to Suspension)
Rebuild is saying it could be Compressor Solenoid Valve, Thermal Valve Sensor, or Compressor.
Any thoughts before replacing more parts?
