I have a 2007 Cayman base model with 100k miles, with the CEL light on for P2402. I replaced the gas cap as it had quite a lot of cracks in the rubber seal.
The CEL came on shortly afterwards with the following symptoms:
1. P2402: Pump motor final stage tank leak diagnosis module in Durametric.
2. It is hard to fill the gas tank from about 1/2 full onwards without the gas pump clicking off all the time.
3. 'Check engine light' and 'Visit Workshop' messages pop up.
What parts would I need to investigate and where are these located?
P2402 - DMTL – Tank Leakage Diagnostics Module, pump output stage
Possible fault causes:
- Open circuit, short circuit to B+ or short circuit to ground of activation line for DMTL pump motor
- Open circuit in the power supply to the DMTL
- DMTL – Tank Leakage Diagnostics Module faulty
- DME control module faulty
Is that somewhere in the frunk behind all the plastics and near the gas tank filler? I haven't disassembled the frunk area on a Cayman before, most of my work takes place from underneath.
Sorry, I cannot find the part number for this unit anywhere, even my dealer parts counter and Pelican Parts doesn't know what a DTML is. Can you assist with that please?
If you know the part number for the tank purge valve as well, I would appreciate it. I may as well change both out to get rid of this error, as I need to smog the car.
