If someone has the actual mix info, is there a difference between Lapis Blue L3A8 and Lapis Blue M5W9?  Apparently the code for Lapis Blue changed MY03 but did the paint color actually change as well?  My paint code sticker on my 2004 calls it metallic but I have also seen this later M5W9 referred to as pearl so are they different?
L3A8 is water based paint as required by the US EPA. It is called "Lapis Metallic Blue".
M5W9 is water based paint as required by the US EPA. It is also called "Lapis Metallic Blue".
Since the two have different part numbers for body shop repairs - I would say they are different.
