I have a 2000 C2 cab. I am getting the lock -unlock with two beeps.
if I manually lock it, I only get one beep and the passenger door fails to lock.
I am trying to pin this down without having to have it scanned
all other function of windows up and down and fob are working.
can this be narrowed to either radio ground for theft or passenger door locking unit?
thanks!!!
Two beeps is an alarm system fault - one beep is an open zone.
The radio ground missing or bad would only give one beep - as it would be an "open zone".
Two beeps hints at a switch or mechanical failure - though a broken wire might have a similar effect.
Another great reason to invest in Durametric software (IMHO) - no guessing.
You might want to test your battery.
I've used Boot Camp with my Durametric for many years now without any problem whatsoever.
