Are these switches (I'm referring to the ones on what I call the horseshoe, e.g., the lock button) momentary on/off or simple on/off devices? And if so which ones? I don't need a lighted switch. Looking to add an FM modulator (one that only is active when energized and only then kills the antenna signal ) to my 986 and would like to keep the look as stock as possible
Edited by cbonilla
Typos
Most Boxsters came with one or more empty slots in the horseshoe trim panel, and most  switches are simple on/off types.
