I'm going to replace the interior lamps with LEDs, which is pretty simple, but the visor vanity mirrors each have two lights that I can't figure out how to replace.  Are these replaceable?  If so, I would appreciate getting instructions.  Thanks.
I replaced mine with yellow hue LEDs, and immediately switched back to incandescent. They were far too bright, even the lowest illumination bulb.
However, I was cautioned when prying out the light unit. They are somewhat fragile.
i used a plastic caulk spreader (I sanded the edges first) and placed wooden shims where I had pried. May try a different wavelength of LED, but for now, I am happy with replacements of the original.
