I have a 2003 986S with a minor alarm fault that I have identified as coming from the glove box. I get one chirp when setting the alarm and if I sit in the car with the alarm on and open the glove box the alarm doesn't trigger
is this the right part number to fix this:
996-622-501-00
Thank you
If there is a beep then there is a fault (somewhere). Do you have the latest Durametric software and the real cable (not a knockoff)?
and do you mean center console storage or glovebox?
I have neither. My indie, a well respected shop, has a durametric and reported no faults when the scanned the alarm system. And it's the gove box not the center console.
I'll phrase my question sligthly differnently: IF (I know that's a big word) the problem was at the glove box door switch, would this be the right part to make it work normally again?
