This is on the driver side intake manifold.  I have a vacuum leak I think, and I am thinking this is at least 1 of them,if not the only one.  I can't find in PET where the hose for this connection goes to, only the pn for the elbow.  Anyone know or have any idea's?  The part that is broken is pn:  999-230-498-40
I have a video too if you want to watch: https://dl.dropboxusercontent.com/u/6314076/Boxster/2017-02-01 04.08.56.mp4
Edited by stlBoxster
Well, search and ye shall find.  Looks like it is the brake booster vacuum line & fitting.  Looks like a common item that breaks and causes leaks.  Off to the dealer to pick one up.
hmmmm . . . , I'll have to check the condition of mine. Every once in a blue moon I get a "difference" in power that, to me, seems like a vacuum issue. I've never taken the time to inspect the vacuum lines but it's on my list of things to check over. Thanks for highlighting.
Curious if anyone knows.  Is this fitting just a connector or does it have a check valve built into it?  If it doesn't have a check valve built in then is there any reason some other method couldn't be used instead of a hard connection?
How did you confirm this is the source of the vacuum leak ?What code did you get - P0300 or another ? Is the rough (?) running worse at idle ? Fuel Trims?
There are several potential methods to locate and confirm  the leak. Which did you use?
1. Smoke machine
2. Propane
3. Carb cleaner/starting fluid(!!!)
4. Engine ear
