I have a new problem with the 2006 Cayenne Turbo 4.5v8
the car lose a lot of power and the rpm is going up and down. I read it out and got follow codes
9 Faults Found:
17503 - Intake Manifold Tuning Valve Position Sensor (G336)
            P1095 - 008 - Short to Plus - Intermittent - MIL ON
18619 - Bank 1; System too Lean at Idle
            P2187 - 001 -
            P2187 - 004 -  - MIL ON
18713 - SAE - Air Leak between MAF and Throttle Body
            P2281 - 001 -
18621 - Bank 2; System too Lean at Idle
            P2189 - 001 -
            P2189 - 004 -  - MIL ON
16886 - Vehicle Speed Sensor
            P0502 - 002 - Signal too Low - Intermittent
16736 - Ignition Control Circuit for Cylinder 2
            P0352 - 004 - Malfunction - Intermittent
Readiness: 0000 1001
00778 - Steering Angle Sensor (G85)
            014 - Defective - Intermittent
            000 -  -
Question where is the G336 Sensor? The idle problem is coming from the leak I think. will check all at Tuesday. someone know how to teach the angle sensor with VCDS?
Wrong forum. You have a 9PA. You want to post this in: https://www.renntech.org/forums/forum/31-9pa-9pa1-cayenne-cayenne-s-cayenne-turbo-cayenne-turbo-s/
And a question - what tool are you using to read these codes? If it isn't a Cayenne specific tool, any code above P999 is questionable since those numbers are manufacturer and model specific.
Edited by deilenberger
smellingpistake
9 Faults Found:
            P2187 - 001 -
            P2281 - 001 -
            P2189 - 001 -
            000 -  -
Looks like you may have recently disconnected the battery or it went flat? The steering angle will clear when you drive it forward a bit with an angle over 20 degrees. Just go for a drive, then clear faults and recheck. Also confirm the battery is 100% is good condition 12.6v when everything is off doors shut no loads on etc.
All the lean codes are for sure a leak Fix It and probably you will have no codes left.
There is no G886  Tuning valves in the manifold so this code is not correct, it's more like a throttle body code is there due to the fact the extra air is pushing the throttle body idle control parameters beyond what it can do with the air leak.
I changed now both MAF Sensors. if the Engine is cold and I start the engine the engine goes out after 5 seconds. if I start and play with the acceleration to keep it going  and the engine get a little warm the engine make no trouble by starting. I delete the codes and drove now 50 miles but  both Turbos don't kick in .I stopped and the engine starts with idle up and down between 500-1000rpm and shut down. if I start the engine and accelerate the engine a couple times to 3500 rpm the idle problem stops and the engine stay on.
2 codes are coming everytime back P1095 and P0299.
Please help
14 minutes ago, thor1974 said:
i disconnect the Battery because they was nearly empty and i had to charge it
Until you have a good working fully charged battery other diagnostic are a waste of time.
