I am in the middle of re-fitting my valve cover and I have a question. Viewing the attached parts diagram, does anyone know where item number 30 (part number 99970176141) is fitted? It is a simple 28mm o-ring. It appears to go on the outside of the valve cover, but there was not one that I removed and there is no obvious place for the o-ring.
The other seal shown in the diagram, item number 27 (part number 99610420300) is green in color and is sandwiched between the valve cover and cam housing. I plan on replacing this seal, it is the o-ring that I cannot figure out!
The car is a 2005 Carrera S. Thanks
