Not sure what else might be holding the Y-tube in.
  • Removed the 2 bolts
  • Removed the 2 hoses from the turbos
  • Removed the small L-shaped hose to the MAF's nipple
  • Removed the hose under the left turbo pipe
  • Loosened the rear most hose clamp. Did not loosen the front one on the coupler hose
Do I need to loosen both clamps that feed forward?  Is there anything else holding the Y-tube in place?
20161225_173256_1_resized.jpgd
  • 9 months later...
