I just replaced my d1s bulbs and the ballasts and after a couple times on turning the lights on, I am getting the check headlight beam adjustment error. The lights move up and down as usual when first turned on. Do new ballast need to be calibrated? I also read that it could be my headlight level sensors on the wheels. What wheels are they located or do all 4 wheels have them. I do not see any modules in durametric that I can use to determine the error.
I just did my bulbs recently (not ballasts) and no calibration was needed. Are you sure you installed the bulbs and got them connected fully? Also, make sure the the housing is seated properly when reinstalling the headlight.
Sent from my iPad using Tapatalk
Those things are fine. I am going to check my headlight leveling sensors but would appreciate if anyone knew which wheels have them
  • 2 years later...
It’s happened to me with me Ca08 after I switch off the car and I adjusted the tyres pressure the warning ⚠️ go off
